oceanwolf
Jan 20, 2022Aspirant
LM1200 wan connection not working
I want to use LM1200 as a failover device in the North Sierras where when we lose power, the broadband goes out in 20 mins. I have the latest firmware and if I connect only LTE modem it works fine. F...
- Jan 23, 2022
Thank you John.
I switched to Router mode and I was able get the traffic through. That caused me another problem since the port numbers using public IP was not translated to local IP.
I switched to Bridge mode again and modem stayed connected and everything works great.
Thanks for all the help, now I need to find external antennas to improve the LTE reception.
Mistercod
Sep 30, 2022Aspirant
So I have a Sim card in The Lm1200 and I get connection but nothing can connect to it wirelessly and I have a router connected to it just wondering if there's a fix?
- JohnPengOct 11, 2022NETGEAR Expert
Mistercod wrote:
So I have a Sim card in The Lm1200 and I get connection but nothing can connect to it wirelessly and I have a router connected to it just wondering if there's a fix?LM1200 is just a wireless modem. It is not a WiFi router. You need to connect a WiFi router to LM1200 LAN port in order to connect your WiFi clients.
John
