CheyenneS
Mar 03, 2021Aspirant
Lm1200 WiFi red light
I bought a byop SIM card from straight talk and got the 55$ plan for unlimited data on it, it gave me a new phone number for the device so I’m assuming it’s been properly set up unless I needed to go ...
Blanca_O
Mar 10, 2021NETGEAR Employee Retired
Hi CheyenneS
We'll make sure that we have Internet connection straight from the LM1200. Please bypass first the router and connect a computer to the LM1200 LAN Port. Can it go online?
If so, reconnect the WiFi router. Connect the Ethernet cable to LM1200 LAN Port and WiFi router WAN/Internet Port.
If not, kindly contact your Internet provider and ask for the APN settings. Then login to LM1200 settings page and add the APN settings.
Blanca
Community Team
