CheyenneS
Mar 03, 2021Aspirant
Lm1200 WiFi red light
I bought a byop SIM card from straight talk and got the 55$ plan for unlimited data on it, it gave me a new phone number for the device so I’m assuming it’s been properly set up unless I needed to go ...
TA89
Mar 06, 2021Aspirant
I'm having the exact same issue! Have you come up with any solution?
Blanca_O
Mar 10, 2021NETGEAR Employee Retired
Hi TA89
Can you please let us know what troubleshooting you've tried?
Blanca
Community Team
- MrssalvatoreAug 27, 2021AspirantI had to change the APN. For AT&T it’s TFDATA.
This worked perfectly for almost a week and now I can’t get an internet connection. Straight talk says it’s all good on their end. Any advice?- Blanca_OSep 01, 2021NETGEAR Employee Retired
Hi Mrssalvatore
Please describe the LM1200 LED status (power, Ethernet LAN, Ethernet WAN, and Signal Strength).
Although Straight talk says it is all good on their end, kindly verify with them to check if you have the right data plan for your device.
Blanca
Community Team- JohnPengSep 02, 2021NETGEAR Expert
For all data connection issue, please make sure you set the APN correctly. LM1200 includes auto APN configurations for most of US carriers, but some MVNOs, it is hard to cover all of MVNOs.
Thanks
John
