TampaBaySailor's avatar
Jan 22, 2022
LM1200 with AT&T phone plan instead of hotspot
I get a much better rate adding an additional phone to my AT&T plan. I have a phone that I can tether, if I loose my cable modem.
Does anyone know if I can use the sim from my phone in a Lm1200 without changing the plan?
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    LM1200 is certified with AT&T. So the AT&T BYOD hotspot plan will work for sure. If your phone plan was from a promotion, most likely, AT&T will blokc the data service to be used with other devices. But you can give it a try.
    Thanks
