m0bov's avatar
m0bov
Initiate
Aug 07, 2023
lm1200 with mind of its own
Hi all, I am in the UK wit a giffgaff SIMS
I am trying to setup the modem as a failover 5G connection.
For the moment, i just want to try and get my laptop using it via the 5G.
Problems:
Can't change ip of device from 5.1 - just says error with a red bar.
Can't update firmware
When I put it into bridge, it does'nt seem to remember it
In fact the only change a can do is to select bridge, anything else gives me the error.
The 5G LED is Red, power is green.
Thanks!
1 Reply
  • Forget all that, its working! I restarted, it found the SIMS and I did the setup wizard, its all now working as failover. Thanks.
