Vonarstonehelm
Dec 07, 2022Aspirant
LM1300 cannot create profile when adding APN
So I am trying to set up my new unit to work with T-Mobile but no matter how I try to add the apn it doesn’t allow me to save it. If I manually select T-Mobile on the main mobile tab it doesn’t actual...
Dec 07, 2022Guru - Experienced User
Did you check with tmobile on that? Seems they've cracked down a bit on sim swapping lately.
- VonarstonehelmDec 07, 2022AspirantSo this is an error message associated with the SIM card and not the unit?
Wish they made that a little more clear. I will reach out to T-Mobile then. Thank you- plemansDec 08, 2022Guru - Experienced User
No clue if thats the issue but its something to check out. Tmobile has been cracking down on sim swapping lately.
