NetizenG
May 08, 2024Follower
Longer USB-A to USB-C power cable for Netgear MR6550?
I need to place my mobile hotspot further away from the outlet than the stock (USB-A To USB-C) power cable allows. Is it okay to use a different (longer) USB-A to USB-C cable and which brand/model are recommended ... or must I use the Netgear supplied one?
I really need a longer cable, at least 5 feet long.
Thank you, any input is appreciated!
1 Reply
should be able to. Just make sure to get a good quality cable
