raymundjohn
May 17, 2023Initiate
LOOKING FOR A POCKET WIFI
Hi everyone, Our company is looking for a bluetooth-enabled portable wifi. Because we can't connect our device to WiFi, they need a Bluetooth connection to access the internet. I've found China ...
michaelkenward
May 18, 2023Guru - Experienced User
What devices are you trying to connect? Laptops? PCs? Something else?
How will they get the Internet connection?
Are you looking for something that uses the mobile/cellphone network?
I know of nothing from Netgear that supports Bluetooth. It does sell mobile devices that might support a Bluetooth add on.
Mobile Hotspots: 5G, 4G LTE - Portable WiFi Devices - NETGEAR
You won't find anything among the Nighthawk Wi-Fi 6 (AX) Mesh Systems devices covered in this section.
raymundjohn
May 18, 2023Initiate
Hi Netgear Team,
I would highly recommend creating a Bluetooth tethering connection for WiFi hotspots. Some brand models enable this feature like Wimax 2+, and I hope the upcoming models will too.
Sample clip is attached
https://drive.google.com/file/d/1hTmcBaz-93bLlhMxIwU8NFXsEmXxEJvc/view?usp=drivesdk
https://drive.google.com/file/d/1PLiYymh49VBCgr0VGTjcedbrtmw57DGS/view?usp=drivesdk
Thank you.
Thank you.
