kal8v9
Feb 05, 2020Aspirant
Looking for a wifi extender or booster
I have a Netgear Nighthawk LTE mobil hotspot router through ATT and my service isnt the best. I am looking at getting a extender or booster. Any recommendation on which one would work the best?
1 Reply
- JohnPengNETGEAR Expert
Please check the AT&T coverage at your location whether it can provide good throughput. If the AT&T coverage is not good enough, WiFi range extender or booster will not help on this.
If you have a good network coverage, but you need to have better WiFi coverage, you can think about using a WiFi Mess System (Best), Range extender (Better) or Booster (good).
Thanks
