PeterUK1
May 25, 2026Guide
Looks like a nearby phone mast isn’t working as it should, sorry.
O2 says Looks like a nearby phone mast isn’t working as it should, sorry. I go check my nice
Nighthawk M2 Mobile Router thats in IP passthrough...its offline! I reboot it it connects fine
Please Netgear fix this I should not need to manually reboot it every time a mast goes down it should auto find the next mast.
- lily64markAspirant
Once the mast went down (or came back online), the M2 completely failed to automatically recover the connection or hunt for the next available tower. It simply stayed offline indefinitely. I had to perform a manual reboot, after which it connected to the network immediately and worked perfectly. paygonline
- PeterUK1Guide
Well it is the newest firmware netgear will not fix a EOL product if its not in IP passthrough its fine which what I had to do.
