Gurugeriki
Sep 14, 2018Aspirant
LOST the GUI access of MR1100 Netgear Router
Dear Experts,
Unfornatualy i have disabled USB+Tethering option and enabled Charge mode only.
Due to this I could not able to access my MR1100 router GUI page :( which is really blocking...
TeeJay74
Sep 15, 2018Virtuoso
You may use Wifi to access webgui, if that fails, then you can use factory reset as a last resort.
Gurugeriki
Sep 15, 2018Aspirant
Thank you sir,
WiFi also I could not be able to connect. Could you please tell me how to do factory reset without GUI access and without WiFi?
- TeeJay74Sep 15, 2018VirtuosoRemove battery cover, battery installed, device on, locate that reset button hole and with paper clip head, do a long press while monitoring LCD, during factory reset do not remove battery.
- GurugerikiSep 15, 2018AspirantThanks a lot sir , it worked.
