Gurugeriki
Sep 14, 2018Aspirant
LOST the GUI access of MR1100 Netgear Router
Dear Experts,
Unfornatualy i have disabled USB+Tethering option and enabled Charge mode only.
Due to this I could not able to access my MR1100 router GUI page :( which is really blocking...
Gurugeriki
Sep 15, 2018Aspirant
Thank you sir,
WiFi also I could not be able to connect. Could you please tell me how to do factory reset without GUI access and without WiFi?
TeeJay74
Sep 15, 2018Virtuoso
Remove battery cover, battery installed, device on, locate that reset button hole and with paper clip head, do a long press while monitoring LCD, during factory reset do not remove battery.
