Snaveejad's avatar
Snaveejad
Follower
Apr 13, 2019
Lte 4g lb2120 wireless password not working
I have purchased this modem to use at a holiday house to connect Arlo pro 2 without home internet, have inserted the sim all good connected arlo base all okay, need to connect wifi to iPad to finish ...
  • Blanca_O's avatar
    Apr 17, 2019
    Hi Snaveejad
    Welcome to NETGEAR Community!
    You can retrieve the WiFi password by accessing the router settings page. Using a computer wired to the router or device that is already connected to the network, open a browser and enter http://192.168.5.1. Once logged in, go to Settings and you should be able to see the Wireless Information.
    Blanca
    Community Team
