TeeJay74
Feb 07, 2018Virtuoso
LTE 4x4 MIMO outdoor antenna
What do you think about my new toy, 4x4 LTE Mimo panel antenna ? I am really looking forward to test it with MR1100 later.
UK-based
Feb 07, 2018Luminary
Looks great TeeJay74 - first one I've seen - none on the market yet. The question is, how are you going to connect it to the MR1100 when there are only 2 connections for external antennas? Are you going to have to open the MR1100 casing?
TeeJay74
Not actually opening, but some drilling etc. There is a plan and hopefully it works. Only time will tell that. For me this is high priority.
This antenna model:
Dawn Communication Co., Ltd.
698-960/1710-2700MHz XX-Pol Wideband Panel Antenna
Model: DB-698/2700X-8-65
