TeeJay74
Feb 07, 2018Virtuoso
LTE 4x4 MIMO outdoor antenna
What do you think about my new toy, 4x4 LTE Mimo panel antenna ? I am really looking forward to test it with MR1100 later.
Jensmobile
May 14, 2018Aspirant
Finally, I got to know why the 4*4 MIMO means. Why netgear just left two antenna slots for the Nighthawk M1, the antenna recommendation here are all for two connector antenna at https://www.store4g.com/blog/netgear-nighthawk-m1-mr1100-external-antenna/
Anyone have the tutorial to install a 4*4 MIMO antenna?
JasonN
May 16, 2018NETGEAR Employee Retired
Hi Jensmobile,
Please refer to the link below and let me know if this works for you. :]
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/M1-antenna-setup/td-p/1538201
- Jason N
- KenethLOct 05, 2018Aspirant
use this link it will help you found out what the max LTE throuphput would be on each band.
https://www.cellmapper.net/4G-speed
