Ksa3344
Jan 25, 2020Apprentice
LTE aggregation Needs to be updated for MR1100
right now the carriers keeps enabling new LTE bands aggregation, for example my MR1100 eus doesn't aggregate 2300+2300+1800 which is new
but it does with 2300+2300 only to my carrier .
Also 1800+1800+700 is not supported but it is supported in Telstra version.
Is it because the firmware or the aggregation methods inside the firmware ?
Also will the MR1100 getting more updates or it will stop cause a newer version is out ?
Sure. That would be great if you can help to collect these information. We will prioritize them for our future maintenance releases
Thanks
- Ksa3344Apprenticea new aggregation worked on phone but doesn't work in nighthawk .
B28+B40
B28+B40+B3- JohnPengNETGEAR Expert
Thanks for the suggestions. Could you please specify which carriers are enabling these CA combos?
- Ksa3344ApprenticeActually I live in Saudi Arabia .
Here we use the EUS version cause it supports all bands of our five Telecom companies here .
and the CA combos i mentioned belongs to Saudi Telecom Company known as STC .
also there is combos for defferint companies i could ask pple to give me the combos for you if its ok .
