Griffo56
May 07, 2019Follower
LTE Antenna
I currently have a poor LTE signal from my carrier. Will connecting an antenna improve this? If so where can I get them in Australia. Thanks in advance
W1lliam
May 08, 2019Virtuoso
External antenna might improve your signal quality, depends if your problem is more on signal strength or stayed on poor band where available bandwidth is not expected.
Check on LTE MIMO antenna from your local store, or online seller, for LTE antenna with TS-9 connector, don't get too long antenna cable (1 meter should be sufficient for home) as cable length would induce more loss.
Try to lock on a band (Google "LTE band lock M1") that gives you better bandwidth in your area, this can be done without spending money and see if it does improve.
William
