Digital999
Mar 23, 2020Luminary
LTE Modem Connectivity question
I am looking for a modem just like the Netgear LTE Broadband Modem. My question revolves around the use of a SIM card with the Netgear device on a GSM network. Can I occasionally remove my ...
Mar 25, 2020Guru - Experienced User
Digital999 wrote:
Can I occasionally remove my SIM card from the phone, insert it into the Netgear device and gain data connectivity?
Maybe - there is an article here from someone who did it: https://www.gizmodo.co.uk/2019/09/swapping-my-phone-sim-card-into-a-mobile-router-wasnt-as-painful-as-i-thought-it-would-be/
There is more than one physical form factor for SIM cards - which is a possible complication. Also if the phone or router is locked to the carrier, migrating the SIM card might not work.
I don't think you'd risk anything by trying it. Note I haven't tried this myself. If others have, it'd be good to chime in (and give the carrier).
