ScottieD
Apr 15, 2020Follower
M1-1100 and Nighthawk R7000 Connect together?
my sister has an m1 router/hotspot thru ATT and a Nighthawk R7000 Router. The Hotspot that my sister has doesnt have a Selection under setup that allowes Teather??? (For some reason??? Might be the software but it says most current ver. installed and it wont let me update to a newer ver even thought there is a new vers. of software?) I have the Exact same M1 Hotspot/router my sister has too but under setup MINE has this "TEATHER Option" which shuts off wifi and enables the Router to accept the signal from the hotspot??? I was told that Bypass works the same as Teather But it DOES not :-( I can Not get the M1 hotspot to work with the Nighthawk R7000 Router and have tried all that I was told IE (click Bypass and shut off DHCP and connet to Nighthawk R7000) Well yea that works 1 time then something happens when the power is turned off and modem is reset ot nighthawk R7000 power is reset??? I guess the Two Devices the M1 and the nighthawk R7000 have the Same Ip and that is the Problem??? I tried changing the Nighthawk R7000 Ip to what another artical said "Outside the range of the M1's IP address range which is 192.168.1.20 to 192.168.1.99" I set the Nighthawk R7000 to Ip 192.168.1.100 and it Either doesnt find it or NO Internet??? I dont know much about Ips and don't have a clue what or how you set them can they be Any Random numbers? Or are there Certain Rules for the Ranges?
What I want to know is
1) How Do I get the M1/Router and The NightHawk R7000 To Work Together, and IE "work Every time they are Turned off and then on Again Without Reprogramming them".
2) How do I get the Software on the M1 Hotspot/Router to the Same Ver of Software as mine With the "Teather Option under the setup tab"
Thanks Scottie D.
You might get better and quicker replies, and find other answers, over in the appropriate sections for your devices:
Nighthawk WiFi Routers
Mobile Routers, Hotspots & ModemsI'd start with the second.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware. - Jfrazier64AspirantDid you ever get an answer
