Rob517
Nov 03, 2021Follower
M1 Can't change WiFi Channels
Hi All, I just setup a new M1 and the interface will allow me to select a new WiFi channel (2.4Ghz) but I cannot "APPLY" it. The button turns red and will not me click it. It will only allow it...
ymm
Nov 08, 2021Tutor
Same here. I'm not able to apply changes to the channel selection. I was told there is no way to disable automatic firmware updates.
ymm
Nov 08, 2021Tutor
Figured it out: To change change channel both main (2.4G) and secondary (5G) need to changed from auto. Worked from the iOS App but not from either Chrome or Edge browsers....
