Wintrmute
May 15, 2018Aspirant
M1 MR1100 traffic stats / usage data SOAP API calls
Hi,
I'm trying to retrieve the current data usage / traffic statistics from my Netgear M1 MR1100 (AU) via the API, so I can automate some behaviour.
(ie. cutting off the internet to devices once my data quota is exceeded, as otherwise the excess data fees can be $600/hour)
I found some info online about the SOAP API, and I'm able to use the SOAP API at /soap/sa_server/ to authenticate, and check which devices are connected to the router -- but the traffic stats endpoint just returns "501:Unsupported Action".
I guess the name of the endpoint has changed since earlier Netgear routers.
Can anyone please advise where the equivalent of urn:NETGEAR-ROUTER:service:DeviceConfig:1#GetTrafficMeterStatistics has moved?
Cheers!
- JasonNNETGEAR Employee Retired
Hi Wintrmute,
Thank you for posting in the community. I was wondering if your issue has been resolved.
If not, then can you please PM me with your firmware // PRI # // Sku # // etc. to me.
What troubleshooting have you done?
Please provide your contact information.
Please be detailed as I will be forwarding this to my internal team for further assistance. :]
- Jason N- WintrmuteAspirant
Hi JasonN,
My issue has not been resolved.
I cannot see traffic statistics via the Genie app, nor via the SOAP API.
Really I only want to see them via the SOAP API, but if you can make the Genie app work, then that should fix the SOAP API too.
Troubleshooting: I checked that I was on the latest firmware version. I checked to see if I could see traffic stats in Genie App, but that did not work either.
Device: Nighthawk M1 MR1100
Firmware: NTG9X50C_10.25.01.01
PRI: 03.22
SKU: Umm, something like MR1100-TLAUS?
Cheers!
- RomanmirAspirant
Any word on this?
