Seandy
Aug 11, 2017Aspirant
M1 Nighthawk and 3G
Hi, I have a single antenna (Axis CLR8-W) which I want to connect to my M1. I was looking for a single FME male to TS9 patch lead but the local Telstra shop sold me one with 2 TS9 leads and said the...
- Aug 11, 2017
Thanks for that; my lead is one FME with 2 x TS9 tails coming off it.
I'll take it back and get a single.
MicW
Aug 11, 2017Luminary
You can connect just one antennae. If just using one make sure to use the left port as it is the primary as viewed from looking at the ports. Does your lead have 2 fme connectors with the 2 TS9? If so just ignore the second one and don't plug it in. The modem does support mimo and that requires 2 antenna.But I ran mine fine on just the one. I have since connected a second antenna to the other port in mimo set up and it gave me roughly a 50% boost in speed.
If the patch lead is 2 ts9 to one fme then I would return it as it is not suitable for your modem
Seandy
