Q101
Jul 31, 2021Follower
M1 nighthawk boot loop
My Nighthawk MR1100 router constantly restarts. It initiates power on and the "NETGEAR" logo shows up on screen, the amber light shows up and then after 3-5 seconds it shuts off again and then powers back on to the same point. After 10 or so loops of this fashion the device reboot loop stops and doesn't power on again (to the loop) until I remove power. I have tried hard resetting it as well as removing sim, however the issue is unresolved.
The model version sku is MR1100-100NAS
Model: MR1100|Nighthawk M1 Mobile Router
1 Reply
Try this in the appropriate section of this community for the MR1100.
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
