louis1976
May 08, 2023Aspirant
M1 Nighthawk data limit
Last week I got an unwanted bill for my data usage. My daughter was streaming movies while connected with the M1100EU nighthawk. There is a data alert feature, but I can't find the data cap fea...
- May 08, 2023
I took a look at mine and didn't see a way in the settings on the device or the app. Or if there is, I couldn't find it.
Might be worth checking through your account to see if your ISP has a hard limit cap they can set.
May 08, 2023Guru - Experienced User
louis1976
May 15, 2023Aspirant
Unfortunately the latter is not possible.
I could change ISP, but you would think such a feature is a must-have.
Thanks for your reply!
