PBnJ4eva
Mar 06, 2020Aspirant
M1 Nighthawk (MR1100-100NAS) w/T-Mobile Broadband Connection
I purchased the MR1100-100NAS (August 2019) and I use T-Mobile for its mobile broadband internet. Initial setup (OOBE) was quick and easy. My M1 is used soley as a modem and I have an Asus RT-AX88U A...
BlightedTalon
Mar 06, 2020Star
Firmware 12.06.11 is kind of a nightmare for a few of us on here, me and another just downgraded our units to 12.05.05 to address this issue, but thanks for the APN info makes me thinks there update in firmware 12.06.11 for AutoAPN 1.30 (is listed as a feature of the update), points to the root of the connection issue if that was your fix. thanks for the info, but I will likely stay on 12.05.05 till this is sorted out in the mean time.
PBnJ4eva
Hi BlightedTalon! I'm surprised by the firmware updates; but I can understand because the technology is "newer". Personally, firmware releases should be more stable, not dinging Netgear because I think they do offer good home products but potentially frustering a 1/3 of your customers (ATT, Verizon, Sprint/T-Mobile) because of a bug is not a good idea.
I'm 100% not recommending someone update to the latest fw, simply putting out information that has worked for me. If this helps other people, great! If not, roll-back the firmware.
