PBnJ4eva
Mar 06, 2020Aspirant
M1 Nighthawk (MR1100-100NAS) w/T-Mobile Broadband Connection
I purchased the MR1100-100NAS (August 2019) and I use T-Mobile for its mobile broadband internet. Initial setup (OOBE) was quick and easy. My M1 is used soley as a modem and I have an Asus RT-AX88U A...
PBnJ4eva
Hi BlightedTalon! I'm surprised by the firmware updates; but I can understand because the technology is "newer". Personally, firmware releases should be more stable, not dinging Netgear because I think they do offer good home products but potentially frustering a 1/3 of your customers (ATT, Verizon, Sprint/T-Mobile) because of a bug is not a good idea.
I'm 100% not recommending someone update to the latest fw, simply putting out information that has worked for me. If this helps other people, great! If not, roll-back the firmware.
BlightedTalon
Mar 06, 2020Star
I am normally one to stay up to date for security reasons but the latest one has to many bugs that affect me and how I use the device I.E. staying on when charging the device over night potentially wasting my data alotment if a device decides to connect to it while at home over night and the like, also the the issue with band selection / not staying connected efectively making the device useless... So until these issues are sorted out I will stay on a stable firmware until such time as issues are addressed... I am a Software Engineer and was a Test Engineer, so I understand things slipping through QA checks but some of these issues are galring of a quick fix, with little testing. not an issue with there hardware as I have 2 of these, just wish they had spent just a few more hours on QA...
- TodoTXMay 15, 2020Aspirant
I am having the similar issues everyone had. My router said broadband disconnected. I have a Tmobile sim. I rebooted and reset several times, did not fix it. I saw the post that the issue might be the firmware so I followed the instructions and successfully rolled back the firmware to v.05, changed the APN but it STILL DOES NOT WORK! Please help. I am at a loss at this point. I called Tmobile as I was thinking it was maybe the sim, but it is not it is an active sim. The router looks good with strength, but just does not show are identify the carrier as Tmobile and show 0 of 0.
- PBnJ4evaMay 16, 2020AspirantI believe it is on T-Mobile's end. The firmware update and APN change worked great a few months ago.
However, I was knocked off the internet yesterday. I checked my account and the line associated with the Netgear modem was no longer associated with a data plan. T-Mobile stated that I had high usage and they would send a refresh signal that will take up to 24 hours. I'm approaching 24 hour mark and I am still waiting.
I'm looking at alternative mobile broadband providers. Nomad internet and OTR mobile look good. While T-Mobile is inexpensive, I can't afford to have the internet dropped mid cycle.- Zach03May 16, 2020AspirantI am having the same issue. On otr. Lost signal yesterday 5/15 as well. Do think I am throttled and booted on Tmobile. Otr tried reset still not working.
