PBnJ4eva
Mar 06, 2020Aspirant
M1 Nighthawk (MR1100-100NAS) w/T-Mobile Broadband Connection
I purchased the MR1100-100NAS (August 2019) and I use T-Mobile for its mobile broadband internet. Initial setup (OOBE) was quick and easy. My M1 is used soley as a modem and I have an Asus RT-AX88U A...
TodoTX
May 15, 2020Aspirant
I am having the similar issues everyone had. My router said broadband disconnected. I have a Tmobile sim. I rebooted and reset several times, did not fix it. I saw the post that the issue might be the firmware so I followed the instructions and successfully rolled back the firmware to v.05, changed the APN but it STILL DOES NOT WORK! Please help. I am at a loss at this point. I called Tmobile as I was thinking it was maybe the sim, but it is not it is an active sim. The router looks good with strength, but just does not show are identify the carrier as Tmobile and show 0 of 0.
PBnJ4eva
May 16, 2020Aspirant
I believe it is on T-Mobile's end. The firmware update and APN change worked great a few months ago.
However, I was knocked off the internet yesterday. I checked my account and the line associated with the Netgear modem was no longer associated with a data plan. T-Mobile stated that I had high usage and they would send a refresh signal that will take up to 24 hours. I'm approaching 24 hour mark and I am still waiting.
I'm looking at alternative mobile broadband providers. Nomad internet and OTR mobile look good. While T-Mobile is inexpensive, I can't afford to have the internet dropped mid cycle.
- Zach03May 16, 2020AspirantI am having the same issue. On otr. Lost signal yesterday 5/15 as well. Do think I am throttled and booted on Tmobile. Otr tried reset still not working.
- PBnJ4evaMay 16, 2020AspirantI'm thinking it's on T-Mobile's side. The modem no longer shows the carrier and it isn't getting assigned an IP address. I'm going to flash the modem firmware to an older version and hopefully that fixes it.
