PBnJ4eva
Mar 06, 2020Aspirant
M1 Nighthawk (MR1100-100NAS) w/T-Mobile Broadband Connection
I purchased the MR1100-100NAS (August 2019) and I use T-Mobile for its mobile broadband internet. Initial setup (OOBE) was quick and easy. My M1 is used soley as a modem and I have an Asus RT-AX88U A...
PBnJ4eva
May 16, 2020Aspirant
I believe it is on T-Mobile's end. The firmware update and APN change worked great a few months ago.
However, I was knocked off the internet yesterday. I checked my account and the line associated with the Netgear modem was no longer associated with a data plan. T-Mobile stated that I had high usage and they would send a refresh signal that will take up to 24 hours. I'm approaching 24 hour mark and I am still waiting.
I'm looking at alternative mobile broadband providers. Nomad internet and OTR mobile look good. While T-Mobile is inexpensive, I can't afford to have the internet dropped mid cycle.
Zach03
I am having the same issue. On otr. Lost signal yesterday 5/15 as well. Do think I am throttled and booted on Tmobile. Otr tried reset still not working.
- PBnJ4evaMay 16, 2020AspirantI'm thinking it's on T-Mobile's side. The modem no longer shows the carrier and it isn't getting assigned an IP address. I'm going to flash the modem firmware to an older version and hopefully that fixes it.
