PBnJ4eva
Mar 06, 2020Aspirant
M1 Nighthawk (MR1100-100NAS) w/T-Mobile Broadband Connection
 I purchased the MR1100-100NAS (August 2019) and I use T-Mobile for its mobile broadband internet. Initial setup (OOBE) was quick and easy. My M1 is used soley as a modem and I have an Asus RT-AX88U A...
PBnJ4eva
May 19, 2020Aspirant
----Update----
I was able to the MR1100 online again. The IMEI needed changed. In order to do this, used the DC Unlocker app. It was fairly simple to use and worth the price to get the nighthawk back online. I recommend using a random IMEI generator for your new IMEI.
modernuser
Jul 14, 2020Aspirant
APN/other settings?
I changed the IMEI, but still get the Broadband Disconnected error message
- PBnJ4evaJul 14, 2020AspirantI've attached my APN settings.
 I took a few additional steps when changing the IMEI settings. In order:
 1) powered off and unplugged Netgear nighthawk
 2) removed sim card
 3) plugged in and powered on nighthawk
 4) used a IMEI random generator for a Samsung tablet
 5) used DC unlocker to change IMEI
 6) powered off nighthawk, waited 30 seconds
 7) inserted sim card and powered on
 I did have to power cycle one more time and I was able to receive data.
 You will want to make sure your sim is getting data, test it with a spare device just to rule out the sim is bad.
 Best of luck!- modernuserJul 14, 2020AspirantStill no luck. Why a Samsung tablet?- PBnJ4evaJul 14, 2020AspirantI told TMO that this line is for a Samsung tablet đ
 If my IMEI change didn't work, I was thinking I'd try the TMO international 15 gb plan because it states unlimited 4g mobile hotspot. Here's the link: https://www.t-mobile.com/support/plans-features/global-plus-15gb
 If you do this, please update! Would be interested in learning.
