andrewv
Aug 16, 2021Tutor
M1 nighthawk won't connect to wpa2 enterprise
its offloading interface just has a place for name of the network also the password.
However the enterprise wpa2 authentication pressumes use of username also
So It won't work
What are the options to upload to wpa2 enterprise wifi connection?
1 Reply
I'm not even sure what you're trying to do here. Your description isn't very detailed and is a bit vague.
Plus you posted in the general routers forum and not the mobile routers forum. (that the M1 is)
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
