mouldog's avatar
mouldog
Follower
Aug 21, 2017
M1 nighthawk
Hi just wondering can you connect a nighthawk high speed wifi router using the ethernet cable to the m1 nighthawk to improve performance/speed
1 Reply
  • I have mine connected to a 16 port switch via ethernet to distribute internet to other devices.It should connect to your router fine.How were you going to use the router to improve speed ? Out of curiosity
