WH6FQE
Oct 29, 2022Aspirant
M1 Router Admin Password Not Being Accepted
I purchased an M1 router and after reading the threads on here about the admin password and trying their suggestions of both "admin" as well as "attadmin", neither one are being accepted to allow me ...
- Oct 29, 2022
For MR1100-100NA, the default admin password should be printed on the device label as well. It may not be the same if someone changed it. To restore the default admin password, you can do a factory reset.
Thanks
John
WH6FQE
SKU: MR1100-100NAS
JohnPeng
Oct 29, 2022NETGEAR Expert
Thanks
John
- WH6FQEOct 29, 2022Aspirant
John,
Thanks. Unfortunately the label inside the device that would have that information is missing, I was able to get the SKU number off of the label on the box that it came in, but that label doesnt give the password.
Let me research how to do a factory reset on it.- JohnPengOct 29, 2022NETGEAR Expert
You can do the factory reset by pressing and holding the HW reset button. You can find it in the battery compartment.
John
Ok, I was able to do a factory reset and am able to log into the router page, but it does not connect to the internet. AT&T just put a new sim card in it yesterday and I have 50G each month, but it does not have internet access.
