DAQ1972
Feb 21, 2021Aspirant
M2 and RAX120 - can you set the RAX120 up to extend the M2?
I have a RAX120 and an M2. Was looking for a way to get the RAX120 to distribute the M2 when home internet is down. Can it be done - any suggestions? If not, can the M2 signal be redistributed and ...
Feb 21, 2021Guru - Experienced User
Is it the MR2100?
If so, that has an ethernet port. you could connect that to the RAX's wan port and either run the rax in access point mode or the M2 in passthrough mode.
the RAX120 doesn't have a failover mode though
- DAQ1972Feb 21, 2021AspirantThanks, obviously I’m not as experienced as many on this form but I like to think I understand the basics. I followed as you suggest and neither platform liked it.
The M2 kept dropping its APN and tried to link up with the 62 network the RAX was pushing out. Then the 62 refused to advertise to more than a couple of devices.
Thinking of replacing the RAX with something simple like the NG 7700 Wi-fi repeater.
Thoughts?
