nrc66's avatar
nrc66
Follower
Sep 10, 2026
M2 connection problems in spain
Cannot connect my m2 in Spain despite inserting a Spanish sim. Any help much appreciated
1 Reply
  • Check whether the M2 supports the Spanish carrier’s network bands and APN settings. Also make sure roaming is enabled if the device/SIM requires it. If the SIM works in a phone but not the M2, then you have to look at the device settings or carrier compatibility.
