jstvj1
Apr 07, 2022Aspirant
M2 connection
Hi I'm trying to connect my M2 via ethernet cable to another router and/or powered switch to connect about three devices (including an ip camera) but it won't work. Is there a setting I need to enabl...
michaelkenward
Apr 08, 2022Guru - Experienced User
jstvj1 wrote:
Hi
I'm trying to connect my M2 via ethernet cable to another router and/or powered switch to connect about three devices (including an ip camera) but it won't work. Is there a setting I need to enable or change please?
This is a case of piling router on router. That can cause chaos.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
In the case of the M2 (probably the MR2100), the best option may depend on this router. It might work to put that in access point mode.
Or someone here may have worked out how to "bridge" the MR2100.
