Loura
Jul 28, 2022Follower
M2 data roaming disabled
At home we were able to work with the M2. Now in France we get the message: Data roaming disabled. We have tried restarting etc. But nothing seems to work.
michaelkenward
Jul 29, 2022Guru - Experienced User
Is that the MR2100?
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual Specify Cellular Settings.
Maybe the bit To turn roaming on and off will help.
