kennngn's avatar
kennngn
M2 how to turn on ethernet
How do you get the Ethernet connection to turn on?
I've had it working once but it seems by luck or black magic.
    You don't turn them on. You plug into the port.
    What is the problem you are trying  fix?
    Is this the MR2100 MobileRouter?
    There is support for this device, including manuals, at the end of this link:
    >>> MR2100 | Product | Support | NETGEAR<<<
    • kennngn's avatar
      kennngn
      Yes it's a MR2100 MobileRouter.
      I plug in Cat6 cable from my NAS to the Ethernet port on the router.
      However it doesn't just become visible to the network.
      After some hunting on the internet I found mention that the router's power button needed to be pressed (touched) after a cable had been plugged in so that the pretty would be activated.
      I have had that work before a couple of times. But last night I spent a couple of fruitless hours and totally failed to get a connection.
