Scottie1745
Mar 30, 2024Follower
M2 IP passthrough problem
I've got an M2 in passthrough mode hooked up to an Asus GS AX3000 router. When I first started it up I had a d/l speed of 200mbps but after 30 mins it drops to 100mbps. The only way to rectify it is to restart the M2 but then the speed drops again after 30mins.
Before this setup I had a B625 with the wifi turned off and connected that through ethernet with no problems.
On the M2 I have wifi permanently disabled but I can't see any other setting I'm missing and the firmware is up to date. Any suggestions?
No RepliesBe the first to reply
