dapatter
Jan 11, 2020Aspirant
M2 passthrough to Nighthawk D7000v2
Hi I have an M2 setup in IP Passthrough, dhcp disabled etc. I can plug pc in on ethernet and connect to the internet fine. When I plug it into the WAN port of the Nighthawk D7000v2, it gets the inter...
Blanca_O
Jan 15, 2020NETGEAR Employee Retired
Hi dapatter
Welcome to NETGEAR Community!
Can you ping the devices connected behind D7000v2?
Have you tried powercycling both D7000v2 and MR2100? If not, please do so and check if it make any difference.
Blanca
Community Team
dapatter
Jan 15, 2020Aspirant
Yes the devices behind the router are reachable and yes the devices have been rebooted several times. I sorted out the issue, looks lile one of the SONOS speakers when plugged in was bringing down the ethernet port on the M2.
