Fhx_30
May 13, 2022Initiate
m5 It only works with the antenna
It only works with the antenna, only if it is separated from the antenna, there is no connection, knowing that my network coverage is excellent, Is there a solution to this problem The problem appeared after connecting and disconnecting the antenna
No RepliesBe the first to reply
