Fhx_30
May 15, 2022Follower
M5 mr5100 Only works on external antenna
M5 mr5100 Only works on external antenna If it is disconnected from the external antenna, it does not work and a message appears mobile broadband disconnected It was working before and there were no p...
JohnPeng
May 15, 2022NETGEAR Expert
Could you please advise which external antenna was used with the device?
Thanks
