jeffbh
Jan 16, 2022Aspirant
M5 (MR5200) - How to enable IP Passthrough?
Model is a Nighthawk M5 5G Mobile Router MR5200 (Unlocked). I am trying to use it as (only) a modem connected to one of the WAN ports of a separate router. I see people saying that they're using th...
JohnPeng
Jan 17, 2022NETGEAR Expert
Please advise your device SKU name and FW version on your device. Is it MR5200-100EUS or MR5200-100NAS?
Thanks
jeffbh
Jan 18, 2022Aspirant
Here’s what Device Info shows. Is this enough info?
NETGEAR
Device Information
PRI Version: 02.02
Web App Version: MR5200-
100EUS 04.02.196.00
Modem Version: MPSS.HI.2.0.c3.5-00010-
SDX55 CPEALL PACK-1.403198.3
NETGEAR
Device Information
PRI Version: 02.02
100EUS 04.02.196.00
- JohnPengJan 18, 2022NETGEAR Expert
Please follow the steps below to enable IP Passthrough.
"You can log in to WebUI and go to Seetings -> Setup -> Mobile Router Setup -> Under IP Passthrough, select ON Disable WiFi on the mobile router.
You can give it a try and le me know if you have any issues. The WAN stability issue is also related carrier network. You may not see the issue for sure.
Thanks"
