ianf1969
Jan 13, 2023Aspirant
M5 MR5200 can you edit billing cycle days
Hi, newbie question. On my M5 I can update gb to 24gb, but the edit pen ONLY appears next to the unit type. Is there an option to change the days?
Finally got in on 10.0.1.1 and NO, you cannot update the billing days, the only setting is 30 days, ONLY the mb/gb figure can be adjusted it seems. Oh well, thanks for the help.
- JohnPengNETGEAR Expert
You can log in to WebUI and set the billing start date. The cycle will be changed accordingly.
Thanks
- ianf1969Aspirant
Hi, thanks - now theres the issue. I can set the mb/gb, NO other value has an edit icon or seemingly able adjust them. So you are saying I should be able to right? I checked the software and its the latest revision, but nothing gives me the option đ
Are you not seeing the same screen as shown below.
Thanks
