ianf1969
Jan 13, 2023Aspirant
M5 MR5200 can you edit billing cycle days
Hi, newbie question. On my M5 I can update gb to 24gb, but the edit pen ONLY appears next to the unit type. Is there an option to change the days?
- Jan 20, 2023
Finally got in on 10.0.1.1 and NO, you cannot update the billing days, the only setting is 30 days, ONLY the mb/gb figure can be adjusted it seems. Oh well, thanks for the help.
JohnPeng
Jan 20, 2023NETGEAR Expert
Please log to WebUI by visiting 192.168.1.1 and see whether you can adjust the data usage display as you want.
The screen you provided is Mobile App
Thanks
John
ianf1969
Jan 20, 2023Aspirant
Ok, thanks for that, but basically 2hrs of my life I cant get back..... http://192.168.1.1
Tried off a 2021 Mac Pro and a 2016 Dell XPS, but unreachable, plugged, unplugged, WIFI etc etc.....
- ianf1969Jan 20, 2023Aspirant
....and an Iphone 11, nothing will connect to this. M5 has had more restarts than frankenstein but nothing can reach this web interface.
