aCiDeViL
Sep 02, 2021Aspirant
M5100 Wifi 5 and M5200 Wifi 6 with exactly same results?
I have M5100 for 2 years that I use it almost dailly. Now I buy M5200 expecting improving my live stream latency after I upgrade all my gear to Wifi 6 but I don´t see any improvements and I don´t und...
aCiDeViL
Sep 03, 2021Aspirant
I don’t u understand what you are saying, did you reply to a wrong thread?
The problem here is why anyone is buying this routers and expend 700€ if we have exactly the same result with a 200€ router old similar model from netgear.
aCiDeViL
Sep 04, 2021Aspirant
I just send my Nighthawk M5200 back to amazon, this router is definetly not ready I hope Netgear come with some firmware upgrade that make a diference because in this moment ipad pro 2021 (M1), internal hotspot mode is a lot better solution in range and latancy then using this M5200 external router from Netgear, unfortunetlly.
- aCiDeViLSep 04, 2021Aspirant
Nighthawk M5100 (Wifi 5 old model)Nighthawk M5200 (wifi6)
Somethis is very wrong with Nighthawk M5200 Router.
This images are taken in the same location, side by side both in 5Ghz only Wifi.
- aCiDeViLSep 06, 2021Aspirant
I cannot edit my topic but I need to make a correction, it´s nighthawk MR1100 vs nighthawk MR5200.
