W1lliam's avatar
W1lliam
Virtuoso
Jul 19, 2023
M6 MR6110-1TLAUS NR5G is not working here
JohnPeng I believe it is the same cause as MR6450-100EUS, NR5G is not working here in Taiwan. Upgraded over NTGX65_12.01.22.00 (dated 2023/5/15) same problem as previous FW. Telstra might not have in...
  • JohnPeng's avatar
    Jul 20, 2023
    Yes. This should be the same issue. But since it took time for Telstra TA on 12.01.22.00. We couldn't get the fix to the official Telstra TA'ed release. But will address this in the next MR for sure. The issue was fixed on 12.01.25.00. So any older release will not have the fix.
    Thanks
    John
