JCITech
Nov 02, 2022Aspirant
M6 Nighthawk mobile hotspot locks up
I received an M6 nighthawk mobile hotspot for work. It connects to my ios, android and home desktop but when I connect to my company laptop it locks up the M6 and I have to disconnect from the networ...
JohnPeng
Nov 02, 2022NETGEAR Expert
Could you please advise how you connect your company laptop to the device, via USB, Ethernet or WiFi?
What company specific software are running on the laptop, such as VPN, etc?
Thanks
John
JCITech
Thank you, I am using wifi and that is how I will use it in the field. I had an older 4glte and it worked fine with this laptop. Both the laptop and the hotspot work with all other devices just not with each other.
- JohnPengNov 02, 2022NETGEAR Expert
Thanks for the information.
Could you please confirm you are using the default WiFi setting, which is 5Ghz only? Please try to change WiFi profile to set it to dualband and see whether that will make any differences?
What is your laptop's brand and model?
Thanks
John
- JCITechNov 03, 2022AspirantThank you, I’ve tried all the different Wi-Fi configurations 5G,dual, 2.4 only.
I’m using a dell lattitude 5520 with Windows 10- JohnPengNov 03, 2022NETGEAR Expert
Please check whether your laptop has the latest WiFi drivers installed for your WiFi adaptor.
Not sure whether this will help resolve the issue. Some users reported WiFi connection issues and they could be resolved by upgrading to the latest WiFi driver on the laptops.
Please give it a try.
Thanks
John
