04zza
Dec 29, 2022Aspirant
M6 Pro - overheating, unreliable
Hi from Brisbane Australia. We have a m6 pro, it is currently connected to powered with the battery in as this seems to be the only way we can get it to work. I’ve tried to run it AC only and it wo...
JohnPeng
Jan 06, 2023NETGEAR Expert
For no battery operation, it is one of the features to support the fixed wireless setup.
Could you please confirm you use the same PA and USB cable shipping with the device? Please provide the photo of the PA and USB cable is possible. There should be a PN on the USB cable label. Please provide the part number.
Thanks
John
04zza
Jan 12, 2023Aspirant
Can you supply in depth instructions on how to run from just power and not battery?
