Harvey1010
Sep 10, 2022Aspirant
M6 Pro connection to existing router
Hi all, I’m trying to connect my m6 pro mobile router to a external WiFi router to get better WiFi range. I can’t get the external router which is a lynksys EA 7300 to get any internet connection when...
Tobinator
Oct 17, 2022Star
Hi Harvey1010 ,
I don't know much about Lynksys EA 7300, but can you try with another Router (if you have one) and check if that works?
I just tested with Netgear's RBR50, connected to my M6 and it works very fine.
Please let me know if you get same behavior when you connect another router to M6.
You can also reset the Lynksys router and try again.
