Harvey1010
Sep 10, 2022Aspirant
M6 Pro connection to existing router
Hi all, I’m trying to connect my m6 pro mobile router to a external WiFi router to get better WiFi range. I can’t get the external router which is a lynksys EA 7300 to get any internet connection when...
ArodiD
Oct 23, 2022NETGEAR Expert
Hi Harvey1010 ,
Follow these steps to setup your M6 Pro as modem to your Linksys router.
- Plug LAN cable from M6 Pro to WAN/Internet port of your Linksys router.
- Power up the M6 Pro without a battery. Use the supplied power adapter and cable.
- Power up the Linksys router.
If the Linksys router's IP range is set to 192.168.1.x then I recommend you change the IP range on either the M6 Pro or Linksys router to something else to avoid any IP conflicts. I also recommend putting the M6 Pro into IP Passthrough Mode if you are going to use the M6 Pro permanently plugged into your Linksys router.
ArodiD
